- 9 Jun 2011
Hi I've got my 3800x @ 4.45ghz @ 1.318v, cant seem to get it stable despite giving it 1.35v is it safe going above this? what's the average overclock for this chip
There is a lot of conflicting advice on vcore voltages for Ryzen 2 for an all core overclock 1.32v seems to be where its settled at for the moment, I think anything over 1.35v and you are definitely taking a risk. What you could do is put the chip back to auto and stress test it for an hour or so and see what the average vcore is over the hour, this should be safe.
There really isn't much point overclocking these chips though unless you are chasing all core benchmark scores. Check out some gaming benchmarks with your overclock and with it on auto, there is little to no difference in fact you may see better results on auto, your rig will certainly run cooler and quieter.
With Ryzen 2 you are better off spending time tuning your memory as you will see benefits from that.
