Yep, play at 1440p and have 165hrz monitor, mostly fps games like battlefield 5/2042...will also be interested in playing fps games that may be released this year, hogwarts, cyberpunk 2077, modern warfare 2 etcWhich games do you play?
What is your fps target @ 1440p?
Gpu first at that res.Yep, play at 1440p and have 165hrz monitor, mostly fps games like battlefield 5/2042...will also be interested in playing fps games that may be released this year, hogwarts, cyberpunk 2077, modern warfare 2 etc
Would also like the cpu i get to be ok with a better gpu should i upgrade it in the future, like a 4070 or similar
Thanks
Thats the thing, the gpu is doing fine, its just 99% of the games i play the gpu usage is hardly in the 90% zone, it drops into the 70s and lower on some games while the cpu usage is up in the 70% usage sometimes, i havent checked to see if a single core is maxed but im sure the cpu is defo holding me back.Gpu first at that res.
Done the bios update, it was easy and all seemed to go well, now just have to save for the 5800x3d
Thanks for all the suggestions and replies
Yep, been looking lolKeep an eye on the members market and you might snag a deal on one.
Thanks
But like i said, my gpu is not hitting in the 90% usage range in any games constantly except halo, some games it drops down to the 70% usage, and others even more, halo is the only game that has my gpu at 99% usage almost all the time.At 1440p you’ll be GPU bound, CPU upgrade will help with 1% lows.
There's something wrong with your setup then, I did a quick benchmark on Cyberpunk which you mentioned you had a problem with. I have a 3900X that is not much stronger than your CPU at gaming with a much stronger GPU (7900XT) and absolutely saturated the GPU at 1440p. This was not at Ultra settings.But like i said, my gpu is not hitting in the 90% usage range in any games constantly except halo, some games it drops down to the 70% usage, and others even more, halo is the only game that has my gpu at 99% usage almost all the time.
Could that be down to my motherboard? or ram? im not sure, im using 3200mhz 16gb ram and a msi gaming plus max x470 motherboard, i just know my gpu should be showing more usage in games
Tried the cyberpunk benchmark at max settings but this time with NO dlss and was getting MUCH higher gpu usage, had a game on battlefield 2042 but turned dlss off and again much much better with the usage in the 90% range much more.There's something wrong with your setup then, I did a quick benchmark on Cyberpunk which you mentioned you had a problem with. I have a 3900X that is not much stronger than your CPU at gaming with a much stronger GPU (7900XT) and absolutely saturated the GPU at 1440p. This was not at Ultra settings.
imageupload
Do you have 2 RAM sticks, are they in the correct slots? What does GPU-Z say about how your PCIE lanes are connected?
Sorry for the offtopic but, what is the members market?Keep an eye on the members market and you might snag a deal on one.
It's a member specific area on the forum were you can buy and sell your hardware/software etc.
You need to have over 1000 posts and to have been a member for a set period of time to gain access.
92 days if you post 10 per day not that far off.Thanks, 1000 post seems a bit far![]()
DLSS renders your game at a lower resolution. The lower the resolution the more taxing it is on your CPU. By removing DLSS you're effectively increasing the render resolution (not ouput resolution). This is causing your GPU to work harder. If you don't gain any meaningful increase in FPS with DLSS enabled, you're best leaving it disabled.Tried the cyberpunk benchmark at max settings but this time with NO dlss and was getting MUCH higher gpu usage, had a game on battlefield 2042 but turned dlss off and again much much better with the usage in the 90% range much more.
Think having dlss on was showing the lower usage for some reason even though i get better fps when its on lol anyhow it all seems ok now
I do have 2 ram sticks and yes they are in the right slots, also have xmp turned on to get the full out of them
Thanks for your replies and suggestions
