3870 problems with catalyst control centre
14 Oct 2006
catalyst control centre is only picking up one of my 3870's but device manager in vista is picking them both up
any help on this so i can enable crossfire
device manager may not be picking them both up, your card has 3 different outputs, its possible for 1 card to show up 3 times within device manager, mine shows up twice and i only have 1 card, i would reccomend you upgrade to the latest bios, make sure the cards are connected properly to the motherboard, the motherboard may require additional power through a molex for running two cards, i would check your crossfire bridges, and your power cables to both cards, i would then check your bios options to see if the 2nd pci-e slot has been disabled or not, and any othr options within the bios
seems using gpu-z both cards are picked up
only ones running at the fll 16x bandwith others running at 4x, could this be a problem ?
how do i check if crossfire is initiated ? ive enabled it in the control centre but gpu-z tells me crossfire is disabled
When I used crossfire, I don't recall CCC picking up 2 GPU's, it just allowed for the option of "Crossfire" to be enabled. GPU-Z reported crossfire enabled, and showed 2 GPUs connected though.
