3870x2 problems
4 Feb 2008
hey guys bought a few things in the past from overlockers but only recently signed up with the forum to see if u guys have any ideas to a problem im having with my 3870X2.
ok now fresh install of vista first of all, when i play games after an undetermined amount of time my pc screen goes off and the red led closest to the front of the case on the 3870x2 lights up. this also happens in windows for no reason the screen will go black and the light will light up. now the PC hasn't crashed as i can still hear the music in the background playing fine (not looping) and if i press the power button it shuts down normally. so ive been thinking thats its either the gfx card or the psu, now the psu is on the crossfirex certified tab for two 3870x2's so 1 shouldn't be a problem. ive had a look in the bios and the rails seem to be at normal levels, no strange voltages. i dont beleive its the psu as its running fine and was with two 3870's in crossfire and is only about 4 months old. its the hiper type r mk2 770w.
i really believe its the gfx card but im not 100%, wondering if any of you guys can steer me in the right direction. also if needed the card is asus and was bought from overclockers maybe 2 months ago, is the warranty handled directly through asus or is it covered by overclockers.
cheers for the help guys ive been racking my brains over this for maybe a week,
ps sorry about the long post.
The red light on the Gfx card tunning on means that there is low or no power coming from the power connection.
Oh! A Hiper PSU.
yeah i read that but it could also mean an error ive heard a few other people but not many having the same problems but info on this problem seems very sketchy at best.
thx for response
there are 3 red led light on the hd3870x2 2 are close together and if on usaly means power issues 3rd light is nearer the frount of the case means card fail and should be returned for testing hope this helps
