3870x2 space in case
Don
20 Feb 2006
Leeds
Hi,
I have a Thermaltake shark case, and i want to get a 3870x2(just about to order). Has anyone got one of these cases as i just wanted to check that it will fit inside.
i have a antec 900 case which is a lot smaller and fits 2 hd3870x2 in it all depends where you sit your hard drives may have to move stuff around but sure they will fit
It will fit inside,
however check your motherboard i found out that it covers 1-2 of my sata ports on a DFI-Infinity so you might want to make sure that isn't an issue before you buy
Cheers for that, The Hdd mount from the side so will not be an issue, i will just check my mobo for the sata ports, Its a J&W IP35 pro.
Thanks Again
