3870X2 vs 3870 CF ?
18 Oct 2007
Which is faster and how is 3870CF performance on a motherboard with 16x/4x slots like most intel chipsets?
Can't seem to find any recent reviews for 3870CF.
I thought that was pretty clear in the first post.
Not terribly clear. I thought it was a case of X2 or CF 3870 too.
As others have said the X2 is simpler and more compact. Even if you didn't plan to go with 3 or 4 gpu's in the future it would be the better choice.
gt
Maybe because I want to know how they compare ? because I can't find any recent reviews that have including 3870CF and want to know how using 16x/4x pcie slots will effect performance, I thought that was pretty clear in the first post.
If you have no interest in the X2 then your only option is CF 3870 so really
the comparison against the X2 is a tad pointless really...
gt
Agree.
Why bother with two cards when one is just as fast.:)
They will both be the same if you have 3870s running at 16x/16x.
There will be no recent reviews with latest drivers because who does reviews of old cards. And prolly the reviews that you can find wont have used a 16x/4x motherboard.
I seriously dought it makes that much of a performance difference.
£160 for both cards is a bargin even if the 4x slot happened to cripple the second card. Why not buy them and then sell them both on and buy a 3870X2 if the 4x slot worries you so much?
