3870XT and 3Dmark
26 Jan 2006
I got a score of ~9k 3dmark 06 with spec in sig (apart from the gfx card).
Not a fresh install and drivers are a mess I guess.
Looks good?
cheers
Yup, cpu is ancient and I am using cats as it was with 1900XTX :p
Just had a go with CCC overclock tool to discover that this card will run
875/1320 which impressed me!
the funny thing is tho that GPU-Z reports 864/1314 (and when stock reported again lower than default 800/1170.
well ... waitting for a new 45nm quad when I figure out which high FSB mobo :)
I got 850Mhz Core and 1000Mhz memory (DDR3) with my 2900Pro 512mb. This was with my old CPU @ 2.8Ghz (AMD X2 SKT939), 1gb of DDR400. I scored 9979 so I'd say you're fine.
core2 helps... I went from a 3800x2 at 2.5 to an e2140 at 2.9 and my 3dmark score has jumped about 2.5k with my overclock 2900pro....
yeah, OCing the 2*** cpus really helps... noticed my score go from like 8000 or so to just over 10000 when she was at 3ghz... sadly, the clock wasn't stable :(
Just got 12170 with my 3850pro...so you can see how having a better CPU helps a lot with your 06 score. (BTW I also got 15,488 with my q6600 and this 3850pro :D )
