3870xt crossfire and Cs:s
12 Jun 2007
Ireland
It seams loads of people having the problem. When you enable crossfire and play counter strike source. When flash bang is thrown the screen starts to shake when crossfire is disabled works perfectly.
I am not sure whats up but if I get flashed banged my screen shakes and really trashes my fps. With a single card I never had that issue.
Does anyone know how to fix that problem because its really annoying.
thanks for help ;)
I'm getting this with my X2 and so are a few others I think, only since the 8.3's. I don't think there is a fix yet. :(
well yea that what im doing but whats the point having 2 graphics cards in your pc and using only one on your favorite game
No point in crossfire for CS:S though, you wont get any gains that you'd notice unless you have super eyesight that allows you to see over 150fps!
p***ing me of still crashes in crysis if it continues this way going to put 8800gts g92 back in
edit: if i knew that dual gpu are pain in the A$$% never would have bought them
