3900x PBO and Auto OC Ryzen Master
30 Apr 2012
Hi Guys,
I downloaded ryzen master and clicked on "auto oc" then clicked apply and test . Before booting I went into the bios and turned on Precision Boost Overdrive .
The computer then boots and ryzen master runs a test ..it now says 4750 max boost per core. Surely this is impossible with a 3900x?? Have I cocked up somewhere?
https://ibb.co/h2d3ZJr
h2d3ZJr
Please see image above any help will be much appreciated.
You will not or extremely unlikely ever see it hitting 4.6 no matter what Ryzen master says.
All its doing is using the "declared" up to 4.6 (hard locked to 4.65 I believe) then PBO is obviously set to allow an extra "up to" 100mhz.
If you disabled PBO which as far as I can see does very little anyway then Ryzen Master would declare 4.65 as the max but you still wont achieve it.
