3900XT to 5800X3D
27 Sep 2005
London innit
Was planning to skip a couple of gens and settle on the next series of AM5, but I think am bottlenecking on gaming with this chip with a mid to high GPU. My workload has changed so it’s mostly gaming now; so thread counts are less important. Worth swapping out and flipping the old CPU out for a decent rebate?
I made the swap and quite happy with it. Although my gpu is most certainly the bottleneck. It’s the best gaming cpu for the am4 platform so I figured it makes sense to swap to it and get plenty of life out my current system with a new gpu at some point.
I went from the 3900X with a bit of PBO tweaking to a 5800X3D, saw some good gains in CPU bound games. VR especially since it helps with the lows and smoothen things out.
Not the 3900xt but went from the 3800x to the 5800x3d and seen massive improvement in both high fps and 1% lows, i game at 1440p with a 3060ti and honestly, its night and day compared to the 3800x
Worth it, but the 5800X3D runs a lot hotter than the 3900X, the only downside really.
Typically won't be maxed in games so not a big deal for now.
I'm mostly gaming at 1440p - 2160p, but some of the more recent titles (especially when I drive resolution down for IQ) really were pushing the load from the GPU to CPU. Cyberpunk was noticeable when doing the path tracing (+mod) on my 7900XT and suspect Starfield will do the same. Was planning to hold out for next gen of AM5, but this is a relatively cheap upgrade and seeing my GPU at < 80% load makes me sad.
Yes, I should think it will be holding back the card in your sig.
I've got the same/similar CPU, and I would imagine that anything beyond a 4070 (non-Ti) or 6800/6900XT will leave some performance on the table when playing at 1440p.
I would have thought you'd be fine for 4K, though.
tbf, its mostly a cyberpunk issue currently as i'm running that probably closer to 1080p internally with path tracing on (via the mod) and seen the 3900xt at 50% with it.
Decided to wait on it, the 3900XT isn't bottlenecking me really in anything but edge cases; will wait for the next round of AM5 and jump on a 8950X or so.
