So what is the best setup for my 3930K and H100i, push or pull?
This will be installed in an Antec P280, along with a 7990. Just want to get the best cooling config set up to accommodate the cooler and the Gpu.
At present my system is set up outside the case Using an Asus P9X79 Pro(until my RIVE comes back from RMA).
Also, what should the stock idle temps be?
