3930k and RIVE BE
22 May 2012
i've got a 3930k and asrock x79-extreme9 setup at the moment. something isn't quite right and i get BSODs, but as the CPU and ram are under warranty i'm thinking of getting a RIVE BE to see if that improves things.
memory will be next on the list after that so what are the safe voltages to use with SB-E and a RIVE BE?
can you set the DRAM voltage to 1.6 or 1.65 with SB-E or is that only safe with IB-E?
Safe volts on CPU 1.4 ish, Safe volts on memory 1.75.
This applies to your Asrock also.
Try XMP and memtest each stick at once to check if its memory related.
