3930K Overclock Look Ok ??
16 Jun 2010
Manchester
Right guys running the 125 strap with the volts below.
Memory is TeamGroup Xtreem LV 16GB C11 2133Mhz stuff running at 2333Mhz with 1.55v
What you guys think ?
VTT is far too high and the VCCSA is high also. Be careful, there are many reports of degrading in C2 3930Ks with high VTT (ME INCLUDED!!). Shouldn't need more than 1.15v-1.2v, i have 1.12v for each.
PLL is quite high too, is this required for stability? X79 is the only platform where i've found increasing this is not required most times.
He left the VTT on AUTO!!!!!
As rossi notes VTT and VCCSA are too high for 24/7, Infact I dont even use that at 5.5ghz+ bench with 2500mhz RAM tight.
1.35V core also seems high for 4.6ghz and PLL 1.7 should easily be enough.
Scale all those volts down slowly VTT and VCCSA should be ok at 1.10 - 1.15.
Ok guys reduced the said volts both the VTT and VCCSA to 1.15 each and the PLL to 1.7 and yes seems fine 8Pack cheers
I was running XMP in the bios and that sets the VTT to 1.35v for some reason but i manually changed it.
Anything else i could do to the clock now ?
I use VTT and VCCSA @ 1.15
The PLL I leave on auto which gives a value of 1.8 it does not like being adjusted up or down on mine.
The above for me is good for anything up to 5.0ghz cpu and 2400mhz mem
