- 10 Sep 2010
- Cornwall, England
Hey guys.
I'm doing a lot of rendering at the moment, a single ray tracing render can take 10 hours so I decided to overclock from stock to 4.2Ghz, I ran Prime95 for 12 hours with 1.260V and a max temp of 80C using a Corsair H60. My RAM is running at stock speed/timings/volts.
The problem is that when I start my computer from a cold boot it will power on for a few seconds, then restart, then power on telling me that the overclock failed and will give me an option to load optimized defaults or enter BIOS.
I can enter the BIOS and save and exit and it will successfully boot at 4.2Ghz and will be stable.
So how can the overclock be stable through prime95 for 12 hours but fail to post?
CPU: Intel Core i7 3930K
RAM: 4 x 2GB Crucial Ballistix Elite 1866Mhz CL9 1.65V
Motherboard: Gigabyte X79 UD3 F7 BIOS
Cooling: Corsair H60
PSU: XFX 1000W Pro platinum
Thanks guys.
Thanks guys.
