3930k temp ok??
19 Oct 2004
London
Hi my 3930k is Overclocked to 4.6 at 1.38 volts and reaches 59 degrees under my EK supremacy block. I have 1x240 thick rad, 1x 120 thick rad and 1x 240 thin rad plus mosfet block and 980ti with a d5 pump on 5.
Is 59 degrees an OK temp? I was hoping for a little less. Gpu maxes out about 40 depending on what I'm doing. I was hoping for high 40s/low 50s for the cpu...
Any thoughts??
How long have you been running it? The thermal paste does take sometime before fully effective. Any your temp is fine. It's hot these days
Those temps are fine,remember your using a 6 core Cpu thats heavily overclocked and at a pretty high voltage ;)
