Hi I've built a pc a while ago, n I've got idle temps of 40c at idle and around 50c-60c when playing most games with stock clocks using a dark rock pro 2 cooler which I believe is ok (correct me if I'm wrong).
Now when I play Sleeping dogs maxed out (including Hi-res texture pack) the heat coming out of my machine is stupid and cpu temps are in the upper 60c and 1 time my pc even decided to turn it self off.
do I need to change my cpu cooler?
my specs are
3930k
Dark Rock pro 2
x2 Corsair Memory Vengeance Low Profile Black 16GB DDR3 1600 MHz
290x windforce edition
xonar essence stx
1 SSD
3 HDD
Asus Rampage 4 extreme
corsair ax1200 psu
3 bequiet 140mm fans
1 corsair 200mm fan
my specs are
3930k
Dark Rock pro 2
xonar essence stx
1 SSD
3 HDD
corsair ax1200 psu
1 corsair 200mm fan
