3960X Rendering
27 Nov 2011
ok over the past few days i have been mmming and aaahhing over the 3960X for my new rig... as mentioned i do a lot of rendering in mental ray through maya and i was wondering if its sensible to have the CPU OC'ed to 4.7GHz and then stress it further with the insane renders i do... i would purchase an H100 cooler to sit ontop but i dont want to exceed 70-80 degrees as it would rapidly reduce the life of the CPU...
any advice welcome!
K
If you keep the voltages low heat shouldn't be too much of a problem I would've thought, the best thing to do is to take it as far as it will go on slightly higher than default volts and then when you hit the wall that requires ridiculous voltage increases for very little in extra clockspeed back off. You might only get 4.5-4.6ghz but frankly that will still be amazingly fast.
Also like zuban says get the 3930K, far better value than 3960X.
