You should post some benchmark results with your rig. You'd have some comparative material by now if you had. There you are, some constructive criticism.
I'm tired so that's all you're getting
Taken from the other thread, so I'm not accused of trolling again
Not sure why I'm supposed to care that you're tired, but any way, enough digressing.
To back up my point about what I claimed in the other thread I will happily run benchmarks on my system. So first up here is Anand's Cinebench R15 taken with conservative clocks on all CPUs.
And my 3970x overclocked to 4.7ghz.
My CPU will do 4.8ghz on multi alone. However, I bought it during the heat wave, so it was pretty close to raggin' it. I know it hits 1285 when oced to 4.8.
Before I bench anything else I want to point out that I can not bench vs their game benchmarks because they are running 770s, I'm running Titan blacks and most games are GPU dependent.
Guru3D 3dmfs.
My Firestrike. CPU 4.7ghz, GPUs 1170mhz.
http://www.3dmark.com/3dm/3905697?
Physics score = 16662. I await to see what the 5820k/5930k can do. Hard to find any data right now, but help me out here... Surely some one has a Haswell E hex already running? 8 Pack's results.
So 8pack said that he's going to use real world clocks. Please post your results on chips that clock well.
3Dmark 11.
http://www.3dmark.com/3dm11/8658990
Seems to be a bit lower than 8packs. Not sure why. If there are any other benchmarks you would like me to run then just LMK.
Too funny
