3d 23" tft or 2d 24" led?
7 Aug 2011
Northern Ireland
I have always loved to buy a 3d monitor and im in desperate need of a new monitor infact i am going to go for a dual display.
I have picked two monitors and i would really appreciate it if you guys had a say on it as well.
One if a 3d 23" tft @ 120hz with 100 thounsand dynamic contrast ratio and the other is a 2d 24 led @ 60 hz with 120 million dynamic contrast ratio
The 24 led is also 50 quid less than the 3d 23, but doesnt come with hieght adjustable stand.
Specs
Asus vg236He 1080p Hd 3d 120hz
Panel Size 23" (58.4cm) Wide Screen
True Resolution1920X1080
Pixel Pitch0.265mm
Brightness(Max)400 cd/?
Contrast Ratio (Max.)100000 :1
Display Color16.7M
Viewing Angle (CR?10) 170°(H) /160°(V)
Acer 24-inch Full HD 1080p Widescreen LED Monitor (2ms,12000000:1, HDMI)
Screen size 24"
Colours 16.7 million
Horizontal/vertical size 531 mm x 299 mm
Resolution 1920 x 1080
Brightness 250 cd/m²
Horizontal/vertical viewing angle Horizontal Viewing Angle 176°
Vertical Viewing Angle 176°
Response time 2ms
Video inputs/Type VGA, HDMI x 2
Frequency range 55 - 75 Hz
Built-in loudspeakers Yes
Max. power consumption Power consumption (standby)
0.55 W
Power consumption (off) 0.45 W
Power Consumption 17.15 W
Dimensions 569 x 425 x 192 mm
Also for the same price as the 3d monitor there is also this
Lg 23 led full 3d monitor/tv
What does this lack when compared to the 24 led monitor
It is60hz and has the ability to male 2d images 3d without nvidIa 3d gc.
It Has been award one of the most flickerfree whilst using 3d
Product DescriptionLG DM2350D-PZ - LCD display - 3D Ready - TFT - 23"
Device TypeLCD display / TFT active matrix - LED backlight
3D TechnologyYes
ColourBlack lacquer
Built-in DevicesStereo speakers, TV tuner, alarm clock
Diagonal Size23" - widescreen
Max Resolution1920 x 1080
Video Format1080p (FullHD)
Display Positions AdjustmentsTilt
Image Aspect Ratio16:9
Response Time5 ms
Image Brightness250 cd/m2
Image Contrast Ratio1000:1 / 5000000:1 (dynamic)
Digital Video StandardHigh-Definition Multimedia Interface (HDMI)
Audio OutputSpeaker(s) - stereo - integrated
Signal Input2xHDMI, VGA
Compliant StandardsFCC Class B certified, CE, TUV, TUV GS
