Ok planning to go watercooling so i just purchased a bigger case. Previously i had the Coolermaster Wavemaster which i was very happy with but it wasent the biggest case in the world and the air flow was very poor. So i went ahead and bought the Gigabyte 3d Aurora and am very happy with it so far. Seems to be a very sturdy case and my overall temps have improved. I am thinking of going for the following kit:
http://www.overclockers.co.uk/showproduct.php?prodid=WC-014-SW&tool=3
My main concern is that the radiator will not fit inside the case where the two 120mm fans are located. I understand that the rad is larger then two 120mm fans but by how much? I want the radiators fittings to be near the PCI slots in my case. I can see in the picture of the kit that the fittings come out quiet far and may not fit in the back of my case. I know that most poeple will tell me to mount the rad outside the case with the provided fittings but i dont have a lot of room behind my case. I am afraid that the tubing will kink too much and stop flow altogether. The width of the rad also concerns me because the space for it to fit in is exactly 120mm wide. Below are some pics of the case to anyone who is not familiar with the layout.
Where i want the radiator to go
The radiator fittings might not fit in this space (Can remove the bracket thats holding the PCI cards in place)
Fittings can't go on top
The width of fan area is only 120mm
I only have about 4 inches of clearance between the back of the case and my wall
Can anyone tell me if it will fit or not?
Thanks
Thanks
