Ok when i bought case i was ok on heat but the front filter has clogged over two months and the temps have risen about 2 degrees all over.
I have since removed the filter and getting better airflow. and now dropped by 5 degrees.
To take front panel off you need to take off side panels. and unclip the front. there are 3 clips each side.
Dust was collecting anyway so cleaning it every 2 weeks isnt,
bad as i clean it anyway due to window.
Quicknote make sure you clear the hdd cage from leads. If your using sata then its fine.
Just thought id post it as im now getting better airflow and hopefully will help some one else.
bad as i clean it anyway due to window.Quicknote make sure you clear the hdd cage from leads. If your using sata then its fine.
