3D Gaming Help
Don
23 Oct 2005
North Yorkshire
Hi all,
My friend has just bought an Asus G51J Laptop that has 3D gaming enabled, it came with the glasses, I guess the novelty will wear off but he wants to try it out. 3D is supported on World of Warcraft that he does have but he can't get the 3D working. He has Stereoscopic 3D enabled but the game is just showing normal graphics.
Video samples etc have all been in 3D.
Any ideas?
Thanks
If you have the 3D drivers installed it should run in 3d as soon as the game starts.
There is a good 3D forum on the NVidia uk website, including a lot of support for WOW.
I don't you know specifically the link for the support? I was looking round the nVidia site and found a lot of info on 3D but not any game specifically.
Can only say how it works on the laptop I have which is G73-3DE, if you either tick the "enable Stereoscopic 3D" box in Nvidia control panel or hit the button on the laptop above keyboard with the ROG symbol which does the same thing then any game you then lauch runs in 3d ie blurry graphics!.. and you just put the glasses on. Sorry can't be of more help.
