This one came in under the radar for me. It is only a 23" passive screen from Asus but if you are like me and do not want to use monitors with TN panels but would like a monitor with Passive 3D then this could be worth a look.
http://www.overclockers.co.uk/showproduct.php?prodid=mo-037-as
if i find any reviews i will link them in this post
edit: here is one review that says as a 2d ips monitor it's o.k. but says you get a lot of ghosting and not much depth in 3d (that is what i found when i owned the 23" lg 2342p passive tn monitor). also this asus ips monitor has a very light anti-glare coating so you will still get reflections but is not "full-on glossy"
http://reviews.cnet.com/lcd-monitors/asus-vg23ah/4505-3174_7-35306085.html
(i think that link is ok as it has some prices, in dollars, of US retailers)
Edit 2: I have just found that the guy at cnet who did that review did not set his monitor up correctly. Apparently he connected the monitor using DVI when you are supposed to use one of the 2 1.4 HDMI connections which you will connect to a graphics card which has a 1.4 specification HDMI output. I am not sure why you need this as i thought passive 3D at 60Hz can use DVI but that is how Asus have configured this monitor. So, no wonder the cnet guy (who likes to punch monitors to see how stable they are, lol) had ghosting in 3D.
