3d mark 01 score for Ti4200 system?
28 Nov 2003
Manchester, UK
Roughly what 3dmark 2001 score should the following system be scoring:
Sempron 2800+ @ 2.0Ghz
Abit KD7-G
64MB GF4 Ti4200
512MB Geil DDR
If its any help the card i have ( which i bilieve is the same as yours ) a 64Mb Gainward ultra - scored 9987 in my dads system with 768Mb RAM and an Athlon XP 2400+, a bit below what I was expecting but a more than in the kids pc with an athlon 900 and 256Mb RAM - 6250
Yep meatloaf its the same card as you, which drivers did you install by the way? Did you use the ones provided on the cd?
No i didnt use the cd, i used the ones im using for my 7900Gt, 84.43
I ran 3dm03 and it got 1500 ish.
Also clocks pretty good as well, got up to 650 on the mem and 310 on the core. Also in coolbits there was no auto detect frequencies option
Bench scores stayed the same tho :confused:
What you getting on yours?
Also, just remebered that the RAM wasnt running in sysnc with the cpu in either system ( 266 cpu bus n dads, 200 in mine, ram at 400 in both ) so that probably caused a bit of a slowdown
I used the drivers provided on the cd, and with the card overclocked a fraction at 260/520 it scores just over 10k.
Seems abit low, will try out some other drivers and see how I get on :)
Duke said:
3DMark01: 14918
P4 2.4GHz @ 3.3
GF4 4200 64MB (320/600)
What drivers are you using there mate?
Update:
Sempron 2800+ @ 2.20 Ghz
Ti4200 @ 260/560
Abit KD7-G
512MB DDR Geil 3200
3dmark 01 is just below 10,800.
Id like to know which drivers ppl recommend for the GF4 Ti range? Thanks :)
