Seems about right,
Get clocking and your prob get closer to 10k.
I doubt your get over 10k with a X2.
. My score below is at 2.8Ghz with my 2900Pro at speed in sig. This is on a 8-10 month old install of XP (which I've still YET to get a fresh install on the go to break 10k).
. I don't know where the CPU limitation ends sadly as my CPU won't give out any longer (2.95Ghz was doable but only for benching). You will hopefully be hitting 3Ghz+.
I'm getting 8200ish on 3dmark 06 with:
A64 4200+ (2.2 ghz)
A8ne mb
2 gig ocz platinum ram
bfg 8800gt oc
all at stock speeds. I'm wondering if I should try overclocking the cpu because I think thats what the bottleneck is. When I oc'd my cpu with a 7800 gs agp it didn't make any change to my scores and it was ok for a week then it started to reboot for no reason (not even when stressing) but that might of been my old mobo (a8v) or some of my settings? I've just built this one using my old x24200 and mem from the old one and its my first complete build so i'm a bit wary of overclocking it but probably will sometime or other.
My max resolution is 1280x1024 as I'm still using a crt. I suppose 3dmark 06 scores don't matter too much as long as crysis etc runs good at least at 1024x768 pref 1280x1024 (I should be getting crysis tomorrow) I'll be happy.
13035 with 6000+ here.![]()
. Nice score btw
I was hopeing to break 10k with the 3870, but it wasnt to be
still twice the performance of my previous 1950pro so its not all bad. its that damed cpu score that needs a boost now. hopefully updated drivers will get more out of the card as they mature though.
). What about looking out for a great clocking 939CPU and fitting that?. Shouldn't cost too much or I wouldn't have suggested it. Also is your motherboard holding back your CPU overclock?.but you needed 2 of the buggers to get that score. what's your score with one card?
i'm sure it's more than 10k but that post of yours is slightly misleading.![]()
lol
1....11263 | mart280 | amd athlon 64 x2 6000+ @ 3211mhz | nvidia 8800gt 512mb @ 720/1950
2....10588 | Voo | amd athlon 64 x2 6000+ @ 3014mhz | nvidia 8800gtx 768mb @ 600/1800
3....10075 | El Jimben | amd opteron 170 @ 2808mhz | nvidia 8800gt 512mb @ 625/900
4....10045 | Greebo | amd athlon 64 x2 4200+ @ 3014mhz | nvidia 8800gts 320mb @ 648/998
5....6556 | roadie | amd athlon 64 x2 3600+ @ 2793mhz | ati x1950xt-x 512mb @ 695/1071
6....5261 | Phatboy | amd athlon 64 x2 3800+ @ 2600mhz | ati x1950gt 512mb @ 600/1550
7....5129 | SkeeterPSA | amd athlon 64 x2 3800+ @ 2600mhz | ati x1950pro 512mb @ 621/742
8....2907 | hp7909 | amd athlon 64 x2 4600+ @ 2832mhz | nvidia 8500gt 256mb @ 600/1200
9....1341 | jaykay | amd athlon 64 x2 3800+ @ 2750mhz | nvidia 6600 128mb @ 420/620
Well your max clock is about the same is my max clock from reports so far (except the BIOS that can maybe see 900Mhz core). What about looking out for a great clocking 939CPU and fitting that?. Shouldn't cost too much or I wouldn't have suggested it. Also is your motherboard holding back your CPU overclock?.
.but you needed 2 of the buggers to get that score. what's your score with one card?![]()
You get the same speed as me at stock volts 2.6Ghz. Your GPU heat is a bit worrying though. I rarely break 77'C with the fan on auto at my own set dynamic fan speeds.
here we go, some amd/single card results from my database....![]()
I think it only made about 800points difference tbh.
. I don't believe you (I really do but would love confirmation on this
).Get testing and prove it. I don't believe you (I really do but would love confirmation on this
