*****3D Mark 11 Advanced FREE with MSI GTX 460 Cards!!!*****
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Were now giving away 3D Mark 11 Advance FREE Download Voucher with qualifying MSI GTX 460 graphics cards, the qualifying cards are listed below:-
MSI GeForce GTX 460 Cyclone 768MB GDDR5 PCI-Express Graphics Card with FREE 3D Mark 11 @ £122.99 inc VAT
- Cyclone Thermal Design
- 9cm PWM Fan for 40% more airflow.
- Nickel-plated copper base for better dissipation.
- Rounded design to prevent keeping dust.
- 15.7% quieter than reference design.
- Military Class Components
- Hi-C Cap provides more precise GPU voltage.
- SSC (Solid State Chock) has No Buzz noise and higher current for better overclocking ability.
- All Solid CAP for longer lifespan.
- MSI Afterburner overclocking utility
- Support Over Voltage function of GPU
- Support advanced fan speed control
- Support burn-in stability test.
- PhysX & 3DVision Surround technology
- Support PhysX technology effects for realist physics effect.
- Support 3DVision Surround technology to provide 3 monitor output simultaneously and real 3D image experience.
Specifications
- Core Speed: 725MHz
- Memory Speed: 768MB GDDR5 3600MHz
- Memory Type: GDDR5
- Memory Size(MB): 768
- Memory Interface: 192 bits
- 2x Dual Link DVI
- 1x mini HDMI
- Support Over Voltage function of GPU, PLL and Memory
- Support advanced fan speed control.
- Online Live Update
- Supplied with FREE download voucher for 3D Mark 11 Advanced Edition worth £19.99
Only £122.99 inc VAT.
ORDER NOW
MSI GeForce GTX 460 HAWK "Super-OC" 1024MB GDDR5 PCI-Express Graphics Card with FREE 3D Mark 11 @ £154.99 inc VAT
The MSI N460GTX Hawk is the world's first graphics card to support voltage adjustment of the GPU, Memory and PLL making speeds, previously though of as impossible, easy to reach!
- Twin Frozr II Thermal Design 18 Degrees Celsuis Cooler and 8.1 dB Quieter!!
- Dual 8CM PWM Fans : Air flow from dual fans can cool down GPU/Memory/Power Module at once.
- Four heat pipes with SuperPipe Technology
- Nickel-plated Copper Base : Large size of Copper Base can dissipate the heat of GPU faster.
- 7+1 Phase PWM Design
- Higher current to GPU Powerv
- Higher overclocking capability
- Better stability in peak load
- SFC (Super Ferrite Choke) : 30% Higher Current Capacity, 10% Power Efficiency Improvement.
- APS (Active Phase Switch) helps save power usage by controlling PWM automatically.
- V-Check Points allow users to read voltage directly by multi-meter.
Specifications
- Core Speed: 780MHz (Beyond 1000MHz possible but not guaranteed)
- Memory Speed: 1024MB GDDR5 3600MHz
- Shader Speed: 1560MHz (Upto 2000MHz possible but not guaranteed)
- Memory Size(MB): 1024
- Memory Interface: 256 bits
- The world’s first graphics card supports voltage adjustment of GPU, Memory, and PLL.
- 7+1 Phase PWM design provides extra 30A current output power to GPU for better overclocking power capability.
- Reduces power consumption by switching of power phases dynamically when not in use (active phase switching)
Only £154.99 inc VAT.
ORDER NOW
MSI GeForce GTX 460 HAWK "Talon Attack" 1024MB GDDR5 PCI-Express Graphics Card with FREE 3D Mark 11 @ £154.99 inc VAT
MSI 460 GTX Hawk "Talon Attack" Special Limited Edition version of the record breaking 460 GTX Hawk. Comes equipped with a core specially selected to ensure maximum stability, 0.4ns GDDR5 super-high speed graphics memory and has enhanced default GPU/Memory/Shader clock speeds of 810/3900/1620 MHz (780/3600/1590 MHz in the original N460GTX HAWK). In 3DMark Vantage benchmark results, its performance surpasses that of the reference GeForce GTX 470, and with MSI's exclusive Afterburner (V2.0.0) overclocking software, triple over-voltage function, and all the military class features of the original hawk, this special edition truly punches well above it's weight class!!
Specifications
- Core Speed: 810MHz (Beyond 1000MHz possible but not guaranteed)
- Memory Speed: 1024MB 0.4ns GDDR5 3900MHz
- Shader Speed: 1620MHz (Upto 2000MHz possible but not guaranteed)
- Memory Type: 0.4ns GDDR5
- CUDA Cores: 336 Units
- The world's first graphics card supports voltage adjustment of GPU, Memory, and PLL.
ORDER NOW
