3d mark 11 crash
23 Oct 2008
I recently got the evga 1080ti ftw3 off the members market part of the forums, before installing that I decided to see what my current card(sapphire 290x, reference blower cooler) could do. as its been sometime since I've used the pc I had to update windows, well anyway when I ran 3d mark after a few mins the fan/s ramped up and the monitor went blank. restarted tried again, this time the pc just shut down. tried setting the fan to 50% and rerunnig, this time it got further but then 3d mark crashed. temps hit 94oC and fan was hitting 5k rpm.
even since I got this pc(4770k, asus maximus vi hero formula) I've had issues, was getting the cpu temps in the 90oCs on stock under load(on stock cooler, an old 120 aio ocuk used to sell and even the arctic freezer can't remember model), so I didn't use it much till I got the water cooling sorted which took awhile to get the parts then a few years to finally put it together. plan was to wc the 290x but I stripped a couple of the screws on the cooler so left it, so waster £50 odd on the block.
before the gpu problem I had to sort out the ram as it was only seeing the ram in slot 3 not slot 1, after faffing about ended up getting it to work by just swapping them around(i.e ram from slot 1 into slot 3 and vice versa).
I did have initial issues with my previous build, issue with bent pin in the cpu socket(the whole torrid affair is on the forums unless the thread has been deleted, I've not looked) but then the pc worked for a couple of years before I upgraded or at least tried to. that pc more or less is still in service as a secondary pc.
error:
Workload Single init returned error message: DXGI call IDXGISwapChain::SetFullscreenState failed:
The requested functionality is not supported by the device or the driver.
DXGI_ERROR_NOT_CURRENTLY_AVAILABLE
I'm going to be using the 1080 ti for a new build, tho that wouldn't go ahead till next month after the new ryzen cpu are released.
p.s found the thread about the bent pin https://forums.overclockers.co.uk/threads/error-45-asrock-extreme7-gen3.18335840/
Well I put the 1080ti in earlier and ran 3D mark 11 and fire strike extreme, both ran fine. I’m starting to think I might have damaged it somehow when I tried to take the cooler off.
No one know what the error means that 3DS mark 11 gave?
Anyone know a safe way of getting the stripped screw out? I managed to get one out using the elastic band trick, didn’t work on the second.
