3D Mark 2003/5 wont start.....
11 Dec 2006
Got a weird prob with 3D Mark 2005 and 2003 not starting up....I've never ran either of them before on my current rig, but thought I'd do a test to see just how poorly my HD2400 is - before getting a better card :)
When I click on the icon to run the prog, the splash screen appears...but gets no further!!
I have to ctl+alt+del to exit the program. I've tried disabling my A Virus but it doesn't make a jot of difference....
Any ideas?
Thx
.....It's poor...!!!
Looks like one of those 1920's flick-a-pile-o-frame-cards jobbies at times!
Don't wanna spend much on a replacement tho, as I'm hopeless at PC gaming with the keyboard after gettin used to my son's Xbox handset for gaming control - I'm always dead by the time I've looked down at the keyboard to see where the 'Shoot' or 'Run' key is :D
I've found some emulator software so that you can plug your Xbox controller into the PC and map the walk-fire-move.......or whatever-you-want-keys into, so it's like playing with your fav console handset.
Seems to work OK on the only PC game I have - Rainbow 6 Vegas - only trouble is, coz the gfx card's so slow - it's un-playable atm :confused:
I think I'll go for a Radeon X1950Pro that I can get for about £70 quid off ebay etc; just to see how I get on......if it's OK - I might THEN think of getting a super-dooper one!!!
