- 7 Jan 2003
- Leicester
The 1st time i ran 3dmark 2006 it was fine,then a week or so later i tried again and after the 3rd graphics test with the serpent imediately after instead of going to the page that says checking configuration the sceen goes dark and the monitor power light flashes,below is the microsoft answer
Error message: STOP 0x000000EA THREAD_STUCK_IN_DEVICE_DRIVER
View products that this article applies to.
Article ID : 293078
Last Review : April 6, 2006
Revision : 3.11
This article was previously published under Q293078
SYMPTOMS
You may receive one of the following Stop error messages:
STOP: 0x100000EA THREAD_STUCK_IN_DEVICE_DRIVER_M
CAUSE
This issue may occur if the display driver is caught in an infinite loop while it waits for the video hardware to become idle. This issue typically indicates a problem with the video hardware or that the display driver cannot program the hardware correctly.
RESOLUTION
To resolve this issue, obtain and install the most current driver for your video adapter, or replace your video card.
I see from a search on google that some other 7900gtx(which I have) have had a similar problem but it seems that its the overclocked ones which this is not.
I formatted and reinstalled windows and it did exactly the same thing at the same point,tried about 6 times now.
Anybody else had a similar problem?
thanks
Article ID : 293078
Revision : 3.11
SYMPTOMS
CAUSE
RESOLUTION
thanks
