3d mark score
5 Sep 2013
UK
Just some quick questions as its my first time with this :)
My spec is
MSI 7990
I5 4670k not overclocked
msi z87-g45 motherboard
window 7 64 bit
Anyway i got a score of 10982 overall ,
162000 on icestrom,
19679 on cloud gate,
10982 fire strike ,
This was just the trial version so i just click run all test and this is what it gave me. So my question is:
1: is this what you would expect from this rig?
2: By the scores it says "Graphics driver is not approved" I dont know why it says that as i got the latest ones. i got Catalyst Version 13.9.
3:And last one, my graphic card not all the time was like making this winny noise, when i had my headset on , it did not matter as i could not hear it but should i be worried? it was not doing it all the time just some times, the fan noise was actually really quite it and my gpu temps never got past 60 which i am not sure if thats good.
Thanks for the help!
Mild coil whine is pretty normal,driver not approved means its a beta driver that's all,score seems right for firestrike
(Thought you meant 3dmark11 for a second)
Ah ok thank si will do , one last question do i need 2 unstall my drivers first and then reinstall or could i just install over them?
Always remove old set mate, head over to Guru3D site and download DDU display driver uninstaller great program.
Also disable ulps give you a boost in frames.
