3D / Rendering workstation build help request
gEd
gEd
25 Jan 2003
South London
Greetings!
A friend of mine has asked me to build him a workstation for running 3ds max, maya and Vue, and maybe Cinema 4d in the future. it will not be used for gaming. The budget is around £2000, up to 2500 if pushed.
I have started to put together the guts of the build to get some idea of pricing but I haven't yet checked the fine detail on the items for compatibility. I am up to £1100 atm so I have £1K to buy cpu, mobo and ram (ideally 32GB or if budget is too tight 16GB in 2 sticks so we can add 2 more later). However I am stumped when it comes to what CPU/mobo to get. I build an overclocked 2500K a couple of years back but I am totally out of the loop on the i7 range and also the xeon range.
This chart gives details on render times which is a useful reference.
http://www.cbscores.com/index.php?sort=rend&order=desc
I would appreciate some guidance on what cpu/combo to get for this task. Do I get a 6 pot i7 and clock the nuts out of it or get an affordable Xeon E5. I am thinking the i7 but which one and which mobo ram to pair it with that will enable me to get a good but 100% reliable clock.
This build needs to last a good few years. Funds are not expected to become available for a replacement for 6 years so i need to get the fastest I can get.
In the future, I am thinking of adding an 1 or 2 nvidia cards such as GTX580 3GB to run iray rendering using CUDA. Therefore I ideally need a mobo with 3 fast pci sockets (and also why I have spec'd a decent PSU)
cheers!
oh not sure how to post what in my basket like you guys all do.
Code:
AMD FirePro W5000 Professional Graphics Card - 2GB - GDDR5 SDRAM		£389.99
Seasonic 860w '80 Plus Platinum' Modular Power Supply				£169.99
Plextor M5S 256GB Solid State Drive - (PX-256M5S)				£139.99
Corsair Obsidian 750D Full Tower Case - Black (CC-9011035-WW)			£138.98
Microsoft Windows 7 Professional SP1 64-Bit - OEM (FQC-08289)			£109.99
Corsair Hydro H100i High Performance Liquid CPU Cooler (CW-9060009-WW)		£99.95
Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD	£43.99
Total : 	£1,107.89
Looks like you might want to get him the i7 4771, has more "instructions" (I have limited knowledge about what that means) but apparently it's better for editing, coding, modelling etc than your normal 4770k - anyone want to verify this?
