- 25 Oct 2011
Are there any alternatives to the "stereoscopic" player? Preferably free? or cheaper. Cant justify spending 70 quid on this software when a WDTV would cost less and do a better job.
My PC hooked to TV using HDMI 1.4a.
I found SP to be very good though and i liked how you can adjust the seperation to reduce ghosting. So any other players out there?
Also on the same note when using this i do get on the left and right of the picture when the 2 pictures are overlapping some oddities. Is this just because of how the PC outputs the files? Should i increase the screen size so that this just gets cropped off the screen? Not sure about how to describe it.
