3D Studio Max - mobile phone modelling
10 Apr 2006
North West
Hi, i have had a look on google but not found anything decent except from one place, but it requires a certain plug-in which i dont have!
Was just wondering if anyone knew of anywhere that has mobile phone tutorials for 3DS Max, looked through the mainstream ones but havent found anything, unless im blind!
Oh and another strange question!
When i go to move, scale or rotate an object, normally if you click the X axis arrow, you can only move the object along the X axis, same goes for Y and Z. There is a small yellow triangle that appears where all 3 of these axis meet, but this has dissapeared and no matter where i click on an object i can move it in any of the 3 directions, getting annoying as when i want to constrain movements to the X axis i cant do it.
Housemate said he had same problem ages ago but cant remember how to get them back.
I found a constraints menu but this doesnt work :(
after looking at the video its good, but too good for my level of modelling :D
Anyone know of anything for beginners much welcome!
Thanks
thanks a lot!
The bulding is for a uni project, need to model exterior and interior and i havent been to a 3D tutorial in a while!
The mobile phone is a favour to my housemate, if i do this then he will help me with some php stuff i cba with :D
