so for the weekend i treated myself to a new benq xl2420t and nvidia 3d vision 2 kit
(running GTX 680)
only tested with a few games so far and although over all i am impressed there is a part in my brain whispering "DSR and get the monies!" haha!
firstly does anyone have a any tips or setup info for any of the following games or for 3D or the monitor in general.
the games and my thoughts:
World of Tanks - I thought this works really well with the 3D... you really do get a sense of depth in game and especially detail on the tank! looks stunning! however the 3D does do a bit of a performance hit, and my fps in WoT hasn't been right for ages :\ (on average getting about 60fps non 3d and about 40 in 3d).
Battlefield 3 - when running about as infantry i did find i had to turn the depth down quite allot or things just didnt look right. but in anything with an overlay... tanks, jets, heli, static AA....it looked friggin' awesome! the overlay really looked like it was coming off the screen and the ingame bezels (e.g. on the static AA) really did appear to arch out. but as i said, as inf sometimes it was a bit hard to focus on shooting, especially if you move your head (real head) the images moves a bit. but still generally sexy looking. but again.... does have a bit of a performance hit especially on highly populated fly maps.
Diablo 3 - this works really well with 3D and i spent agessss playing it yesterday
all the labels, tool bars and mouse seem to be on a layer that's jumping out of the screen at you! whilst also having a great depth of field at the player level too.... the monsters, scenery and spells look fantastic!!! again, takes a bit of a performance hit but nothing substantial, also read somewhere that you should turn off shadows as they don;t render properly in 3d? not so sure about that but i'll test when i get home.
Arma2 - didn't really get round to testing this but it's apparently pretty good... i imagine day-z will be a whole new level of pants filling in 3d xD but the performance hit i imagine could be quite bad as well... run it with almost everything maxed out so could get stuttery (another 680 it is then
CS:GO - this i think was the least optimised for 3D (stating on the screen it's not officially supported, nor is it in the compatibility list). using some of the smallest increments of depth it does bring the game out of the screen a bit.... however, anything more and i found i wasn't shooting straight lol! something about it wasn't quite right... like the cross-hair didn't seem to be in place... and it also became very hard to see against the sandstone walls with the classic green look. so far i've only been adjusting the depth of field (ctrl f3/f4) but there are more things to play about with which could help (ctrl f5/f6...tho not sure what they do.... haha).
some issues i have encountered with the kit are:
....firstly the hard plastic arms of the glasses.... really wish these were more flexible. don;t get me wrong, they are comfortable on the nose and doesn't bother me wearing them.... if they are the only thing on your head.... where as if you are like me and use a headset.... it's a bit poo as the arms stop the cups from sealing around the ears and with that added pressure from the headset the ends dig in a little. my way around this was to just simply put the arms on the top edge of the cups. ok the glasses are at a bit of an angle to my eyes but so long as the glasses aren't at tooo silly an angle it doesn't affect the performance, also takes some of the weight to that helps a little.
secondly, a bit of background info. when you want to watch something in 3d e.g. a game, with the kit all set up, all ya should need to do if launch the game, as the game is loading, nvidia detects possible 3d content and enables the vision transmitter (the green light glows brighter), the monitor goes blank then comes back on with the 3D mode light shining, a quick tap of the side of the glasses and boom.... 3D schiznezzz!!!!
but unfortunately that isn't always the case. with diablo 3 it does everything except change monitor mode :\ the screen will have the stereoscopic image displayed but the monitor will be in 2D 120Hz mode. it will even come up with a message saying that it needs to be in that mode for the 3d to work... so i think fine,. i'll try disabling it and re-enabling it. ctrl+t and it puts the image back to normal.... but then the monitor goes into 3D mode? hummm.... ok? i'll just put 3D back on and it should work? ctrl+t again, image changes to stereoscopic... but then the monitor goes blank, comes back and it's back in 2d mode
dammit!!!!!!! so far the work around for it is if i load up origin, then launch the game it will go into 3D mode no problem.
had a similar issue with CS:GO after i alt tabbed. at first it loaded up fine, but after i alt tabbed it switched which mode was active when i had 3d on
but just closed the game and started again and it was fine.
so yea... little bit of a review and thoughts on these products
not sure if it's for me yet but i have a little while longer yet before i have to decide about DSR as i am testing it atm.
also wondering what other games have people used this with and what were their results? anyone had similar issues to mine? anyone have any setting preferences? can i set up 3d profiles for each game does anyone know? ...should i ***** another 400 squids and go SLI for uber 3D FPS?
tl : dr - 3D vision is pretty funkay, works good in most games, not so great in others. solid product but glasses design could be altered. thoughts, opinions, tips?
(running GTX 680)only tested with a few games so far and although over all i am impressed there is a part in my brain whispering "DSR and get the monies!" haha!
all the labels, tool bars and mouse seem to be on a layer that's jumping out of the screen at you! whilst also having a great depth of field at the player level too.... the monsters, scenery and spells look fantastic!!! again, takes a bit of a performance hit but nothing substantial, also read somewhere that you should turn off shadows as they don;t render properly in 3d? not so sure about that but i'll test when i get home.Arma2 - didn't really get round to testing this but it's apparently pretty good... i imagine day-z will be a whole new level of pants filling in 3d xD but the performance hit i imagine could be quite bad as well... run it with almost everything maxed out so could get stuttery (another 680 it is then
).CS:GO - this i think was the least optimised for 3D (stating on the screen it's not officially supported, nor is it in the compatibility list). using some of the smallest increments of depth it does bring the game out of the screen a bit.... however, anything more and i found i wasn't shooting straight lol! something about it wasn't quite right... like the cross-hair didn't seem to be in place... and it also became very hard to see against the sandstone walls with the classic green look. so far i've only been adjusting the depth of field (ctrl f3/f4) but there are more things to play about with which could help (ctrl f5/f6...tho not sure what they do.... haha).
dammit!!!!!!! so far the work around for it is if i load up origin, then launch the game it will go into 3D mode no problem.had a similar issue with CS:GO after i alt tabbed. at first it loaded up fine, but after i alt tabbed it switched which mode was active when i had 3d on
but just closed the game and started again and it was fine.///////
not sure if it's for me yet but i have a little while longer yet before i have to decide about DSR as i am testing it atm.also wondering what other games have people used this with and what were their results? anyone had similar issues to mine? anyone have any setting preferences? can i set up 3d profiles for each game does anyone know? ...should i ***** another 400 squids and go SLI for uber 3D FPS?
and i know what ya mean.... aiming in FPS games feels weird... although the holo sight in BF3 looks awesome and like it's really infront of me xD
