3D Vision Question...
12 May 2010
West Bromwich
I tried 3D Vision discover, with the red and blue glasses, and had to almost turn every graphical enhancement in games down to nothingness to enable a reasonable FPS.
Is the case the same with normal 3D Vision, with the official glasses?
I'm asking the question because I'm not sure whether to upgrade monitor or graphics card 1st.
Card is 9800GX2, overclocked to 725MHz
AFAIK it has to draw everything twice so it halves your fps straight off the bat. If I was going 3D I would also go sli for sure. Twin 460/470's should do the trick.
