3D Vision
16 Nov 2008
West Sussex
Hey guys not sure what section to post this in really but i am having trouble setting up nvidai 3d vision. In the set up wizard i got some writing at the bottom in red about not being in stereoscpoic mode and cant go on to configure the glasses just said test was not complete. anyone else experianced the same problems? Using 266.77 drivers if that helps
Thanks in advance :)
Single monitor yeah? as Anything below 400 range doesn't support 3d vision SURROUND.
Not sure if it has anything to do with dual GPU. And you have 3D Vision ready monitor yeah. 120hz as well?
You need to enable stereo(scopic) mode
in nvidia control panel / resoltion is you refresh rate set to 120hz
and in the 3d setings tab is the enable stereoscopic 3D ticked?
I had this problem with mine too and found i'd got the wrong usb driver. You have to download the correct usb driver to match your version of graphics driver and I think this will solve your problem. Good luck
