3DMark 05 Vs 06
3 Jan 2004
Bournemouth
Why would a card get higher in one than the other>?
eg. i'm comparing 2 cards for laptops, one is better than the other at '05 but loses on '06 :confused:
how am i supposed to tell which one is better?
I would say the one that performs best on 06 is the better one as 06 uses a lot more modern features and things that are much more likely to be used in todays games, HDR for example
but that means they have to find machines with exact cpu and memory setups and only the gfx changes - unpossible
Perhaps, but if you were choosing a laptop, would you ONLY look at the spec of the video card, or the system as a whole?
As a whole obviously.
That is the reason why the 3dmark orb exists. configure it to find a system similar to your own and change the gfx card .
