3dmark 06 score
CSA
CSA
20 Apr 2006
Lancashire
Just built a new system but kept my old 1800xt , giunna upgrade that in the next month or two
6600 c2d at stock for now, awaiting new cooler
1800xt at stock
2gb geil ddr2 ultra LL
ds3p mobo
antec 500w psu
winxp
im getting around 4700 marks, does this look about right ?
overclock the 6600 and that X1800
with my x2 4200 @ 2.8GHz and my X1900XT @ 720/880 i score about 6800 in 06
Thanks for the replies guys, after clocking my 6600 to 3.2ghz and clocking the 1800xt alittle ive managed to hit 5400 in 06
Im hoping thats about right for this set up ?
in my very limited experience the 1800's are decent clockers but the temps can run high. your results are very much in line with what i had with a 1800.
i couldnt clock mine much as it was hitting 90c under load according to the CCC.
hmmm, well i spose the X1900's were meant to run cooler. after just testing again with more then enough volts running through it it was hitting 73 with stock fan at 5000rpm :cool: i scored 6300. must have clocked it bit more last time :(
Oclocks on the 1800 are via overdrive and are 688/792 , i dont really push it any further ive burned out my last 3 Gcards, i want this to last till i upgrade it in a month or two :D
You should use ATi tool to oc your x1800xt, the memory can go to at least 815mhz without problems. But I tend to find using the stress test in ATi tool the core can't go above 680~ :/
Hi,
@lodsamoney - is your GTS the 640mb and was it pre overclocked at all? I was just wondering as i have an E6600 @ 3.5Ghz and i have OC'd my 8800GTS OC2 to 630/920 and i score 11008 in 3DMark06
