3DMark 11 - Crashes/hangs?
15 Nov 2003
Marlow
So I downloaded this off Steam last night, and each time I run it, it hangs within a few seconds. If I press ESC it stops and all is OK.
I noticed it wasn't the latest version (1.05?) which I then manually downloaded but that said it wasn't compatible with my OS?
Any suggestions on how to resolve the hang? Or where to find a working version?
I think I had this before, its either is needs to update a "redistribs" or you need to update the Futuremark SystemInfo.
1) The files that you get with games in a folder like DX and Microsoft Visual C++ 2012 Redistributable (x64) etc etc, you would need to know what ones to grab from MS site.
2) Yes that is "Futuremark SysInfo" and sometimes it will not run till its updated.
(1) - Groan! Sounds like a faff!
(2) - Well 3DMark11 runs.. It's just when starting the benchmark, about 1-2 seconds into it, it hangs... I'll give this an update though!
1) Yes and if I knew/Could remember all names I would list them for you.
If you have any games installed look in there folder for the files in the folder I mentioned above.
2) That does need updated at times but may not be your issue.
I do remember same issue though but cannot remember 100%.
