- 22 Mar 2017
- Poland
Hi. I am getting weird single stutter/fps drop in 3dmark 11 HIGH TEMPLE demo on extreme details. It will stutter always on the same spot. Drop ( for a 1 second ) from 60 fps to 50 fps and back again to 60fps.
It happens very randomly but on the same spot in test. Some runs are without this drop, but sometimes it will drop exactly on the same spot in benchmark.
And exactly on the same spot in benchmark. I post screen,fps drop place:
My pc: 6700K stock ( normal temps ), 1080 ti reference ( 80C normal temps ). So its not thermal throttling.
I checked gpu clock during that spike,and clock are normal. There is only gpu load drop for 1 second.
I was using the Gigabyte Xtreme Gtx 1080 graphics before and this never happened. I moved up to the new 1080 ti and this strange issue is happening. Running different title of games seems fine without any stutter or other issues.
Any ideas?
Using Windows 10 . Drivers 378.92
Any ideas?
