3Dmark 11
8 May 2009
Was just using 3Dmark 11 performance mode and got a rating of P9219 and a graphics rating of 10923 is that good for my system specs? specs in sig below. The main reason I want to know is I am getting poor performance in a couple of games and can't tell if its a driver issue or hardware.
Seems correct for your spec but we will need some more info such as:
1. What CPU frequency are you running? Any OC?
2. What games do you play and at what resolution?
3. What do you mean by bad performance?
There are probably a few things you can do to optimise your system but as above a little more info needed.
1-stock sooo 2.8 Ghz i think
2-1680x1050 currently but this is temporary as my good monitor died so I am currently saving for a new one
3-um alan wake and world of tanks are two I get surprisingly shoddy performance from sort of 40fps average but dropping down to 30/25fps semi-regularly
Yes your 3dmark11 score looks about right.
If you are running your CPU @2.8 this could be what is causing you problems with your games. See if you can get a better cooler for your CPU and overclock it a bit.
so yeah if it isn't a hardware issue any idea why I am now averaging like 30 fps in alan wake? I am not overheating I don't think i get great fps in crysis 3 and metro LL which are far more intensive
