3DMark help
18 Mar 2007
Please could someone help me with 3DMark.
I have installed both 05 and 06 - unfortunately whenever I run them it gets to the checking system details and then I get the dreaded blue screen with error messages and the PC reboots - it then takes ages to find my RAID array.
Why would it do this? Anything I can do to sort it out?
Not sure if connected but have been having a few issues with 1.2V HT - on auto this showed a reading of 1.5v - when I set it manually to 1.3v it shows as 1.36v - so probably okay - but then when running MBM in orthos, AI probe shows the voltage dropping to 0.0v then up to 1.5v then down to 1.36 every so often. WHat's going on here? Is it a motherboard prob or a monitoring issue? How would I know if the HT was actually at 0.0 volts as Oblivion etc all run find no matter how long I play them etc.
Many thanks
Nic
