3DS Max & Facial Studio (urgent!)
5 Apr 2003
Does anyone know how to save a file in facial studio as a .FBX file so i can import it to 3dsmax? The option is there in the menu, but its not highlighted..
Thanks for any replies, Sainte
disclaimer: I think i misread your post - wonder why it's greyed out. Maybe it's a trial version limitation? Should still be able to export it as something...
Never used whatever software you just mentioned, but can it export as an .obj/.3ds file?
edit, isn't facial studio a plugin for max? :confused:
another edit - ah there's a standalone version.
Facial Studio exports to every major 3d applications including 3ds max, Cinema4D, LightWave, Maya, MotionBuilder, XSI and many others by using the FBX file format.
yeh its just i cant save my file as an .FBX for some reason. The program only allows you to save as a .FS file (facial studio) or a .FBX, so it's pretty wierd why i cant do that.
it doesnt seem to work... does anyone know of any other programs that will create a head from pictures that you can export to 3dsmax?
