Just got a new laptop (Toshiba A300 21H) and its got 3 GB of ram and Vista 32 bit and am just wondering if its worth putting 4GB ram in, will it make any difference at all , I've got 2 x2GB layin round so wont cost me any thing but is it worth it ?
If you have a 32 bit OEM Key, am I right in assuming that you can use a 64 bit disc with it?
OK, thanks. I heard that Vista should have around 2gb of RAM so I just assumed that a laptop running Vista would benefit from 4gb.
So I won't be able to use all of the 4gb but I'll be able to use some/most of it.
