£3k WC build?
Go Dan Dan the CAD making man!
That me appearently. :)
YOUR BASKET
2 x sapphire radeon r9 290x 4096mb gddr5 pci-express graphics card £429.95 (£859.90)
1 x intel core i7-4770k 3.50ghz (haswell) socket lga1150 processor - retail £251.99
1 x msi z87 mpower intel z87 (socket 1150) ddr3 atx motherboard £199.99
1 x seasonic 860w '80 plus platinum' modular power supply £179.99
1 x samsung 250gb ssd 840 evo sata 6gb/s basic - (mz-7te250bw) £146.99
1 x corsair obsidian 750d full tower case - black (cc-9011035-ww) £134.99
1 x ek water blocks ek-d5 vario x-res 140 (incl. pump) £107.99
2 x ek water blocks ek-fc r9-290x - nickel (original csq) £99.95 (£199.90)
2 x avexir mpower yellow series 8gb (2x4gb) ddr3 pc3-19200c10 2400mhz dual channel memory kit (avd3u24001004g-2cm) £89.99 (£179.98)
1 x seagate barracuda 3tb 7200rpm sata 6gb/s 64mb cache - oem (st3000dm001) hdd £89.99
1 x xspc ex360 crossflow radiator £52.99
1 x ek water blocks ek-supremacy £49.99
1 x xspc ex240 crossflow radiator £44.99
1 x ek-fc bridge dual serial 3-slot csq plexi £18.98
5 x akasa ak-fn059 120mm ultra quiet venom viper cool fan - 3/4 pin £11.99 (£59.95)
1 x bitfenix alchemy 24pin atx extension 30cm - blue £8.99
1 x mayhems xt-1 150ml uv blue coolant £6.98
4 x bitfenix 6+2-pin pcie extension 45cm - sleeved blue/black £5.99 (£23.96)
1 x xspc highflex hose 7/16" id, 5/8" od, 15.9/11.1mm, 2m, clear/uv £5.99
1 x bitfenix alchemy 8pin eps extension 45cm - blue £5.99
2 x mayhems ultra pure h20 watercooling fluid 1l £4.99 (£9.98)
2 x bitfenix alchemy molex to 3pin x3 fan adaptor 7v 20cm - blue £4.99 (£9.98)
1 x bitfenix alchemy 2pin i/o extension 30cm - blue £3.95
2 x bitfenix alchemy molex extension adaptor 45cm - blue £3.95 (£7.90)
12 x xspc g1/4" to 7/16" id, 5/8" od compression fitting (black chrome) £2.99 (£35.88)
total : £2,718.37 (includes shipping : £16.85).
yellow board, ram and fans.
blue loop (clear blocks to show blue coolant) and cables. :)
thoughts? :)
also, i know wow is a cpu heavy game but check this out: http://www.tomshardware.com/reviews/core-i7-3930k-3820-test-benchmark,3090-12.html
Comparison of 3930k and 2600k (bear in mind the 4770k is 2 generations above the 2600k, and the 4930k is only one gen above the 3930k)
He get's a lot of money, he works for one of the top gaming developer company.
EDIT:
Changed it a bit since he's a nvidia fanboy, I forgot to say...
YOUR BASKET
2 x EVGA GeForce GTX 780Ti 3072MB GDDR5 PCI-Express Graphics Card (03G-P4-2881-KR) £569.99 (£1,139.98)
1 x Intel 4930K 3.40GHz (Ivybridge-E) Socket LGA2011 Processor - Retail (BX80633I74930K) £439.99
1 x Corsair Obsidian 900D Super Tower Case (CC-9011022-WW) £299.99
1 x MSI X79A-GD65 (8D) Intel X79 (Socket 2011) DDR3 Motherboard £199.99
1 x Seasonic 860w '80 Plus Platinum' Modular Power Supply £179.99
1 x Samsung 250GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE250BW) £146.99
1 x EK Water Blocks EK-D5 Vario X-RES 140 (incl. pump) £107.99
1 x Seagate Barracuda 3TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST3000DM001) HDD £89.99
2 x Avexir MPower Yellow Series 8GB (2x4GB) DDR3 PC3-19200C10 2400MHz Dual Channel Memory Kit (AVD3U24001004G-2CM) £89.99 (£179.98)
2 x EK Water Blocks EK-FC Titan & 780 - Nickel (Original CSQ) £84.95 (£169.90)
1 x XSPC EX360 Crossflow Radiator £52.99
1 x EK Water Blocks EK-Supremacy £49.99
1 x XSPC EX240 Crossflow Radiator £44.99
1 x EK-FC Bridge DUAL Serial 3-Slot CSQ Plexi £18.98
5 x Akasa AK-FN059 120mm Ultra Quiet Venom Viper Cool Fan - 3/4 Pin £11.99 (£59.95)
1 x BitFenix Alchemy 24pin ATX extension 30cm - Blue £8.99
1 x Mayhems XT-1 150ml UV Blue Coolant £6.98
1 x XSPC HighFlex Hose 7/16" ID, 5/8" OD, 15.9/11.1mm, 2m, Clear/UV £5.99
4 x BitFenix 6+2-Pin PCIe Extension 45cm - sleeved blue/black £5.99 (£23.96)
1 x BitFenix Alchemy 8pin EPS extension 45cm - Blue £5.99
2 x BitFenix Alchemy Molex to 3pin x3 Fan adaptor 7V 20cm - Blue £4.99 (£9.98)
2 x Mayhems Ultra Pure H20 Watercooling Fluid 1L £4.99 (£9.98)
2 x BitFenix Alchemy Molex Extension Adaptor 45cm - Blue £3.95 (£7.90)
1 x BitFenix Alchemy 2pin I/O extension 30cm - Blue £3.95
12 x XSPC G1/4" to 7/16" ID, 5/8" OD Compression Fitting (Black Chrome) £2.99 (£35.88)
Total : £3,321.46 (includes shipping : £16.85).
Changed the colour scheme around:
YOUR BASKET
2 x Inno3D GeForce GTX 780Ti 3072MB GDDR5 PCI-Express Graphics Card (N78T-1DDN-L5HS) £549.95 (£916.58)
1 x Gigabyte X79S-UP5-Wifi Intel X79 (Socket 2011) DDR3 Motherboard £284.99
1 x Corsair Obsidian 750D Full Tower Case - Black (CC-9011035-WW) £134.99
2 x Corsair Vengeance Pro Blue 8GB (2x4GB) DDR3 PC3-14900C9 1866MHz Dual Channel Memory Kit (CMY8GX3M2A1866C9B) £79.99 (£159.98)
1 x Mayhems Dye UV Laser Green 15ml £5.48
Total : £3,179.88 (includes shipping : £16.85).
Also, i know WoW is a CPU heavy game but check this out: http://www.tomshardware.com/reviews/core-i7-3930k-3820-test-benchmark,3090-12.html
In case anyone just glanced at the charts in that link it's worth pointing out that we should ignore the 8*AA results as they're totally GPU bound. Still, thats a pretty narrow gap between the chips! Would have expected a 3930k to be further ahead. Thanks for the link! :)
Just one thing to make sure you check, go to EKs website and check that the gfx cards are reference design and the water block will fit fine. They have something called the cooling configurator I think where you can search what is compatible.
E-I
Doesn't look like the KFA2 780Ti would be compatible with their full cover blocks.
Worth checking alternative 780Ti's
To be honest, paying 3k for WoW pc is way to much.
I played it on max settings with gtx660ti x2 sli.
Graphics won't change much no matter how much overkill you put in that case.
If he still insists, Id put a single gtx780ti Classy in there, just wait till they release in December.
Had a bit of a re-think on this one. :)
YOUR BASKET
2 x EVGA GeForce GTX 780 3072MB GDDR5 PCI-Express Graphics Card (03G-P4-2781-KR) £407.99 (£815.98)
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £275.99
1 x Phanteks Enthoo Primo Full Tower Case £199.99
1 x Corsair Professional Series AX 860W '80 Plus Platinum' Modular Power Supply (CP-9020044-UK) £167.99
1 x Samsung 250GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE250BW) £149.99
1 x Gigabyte Z87X-UD3H Intel Z87 (Socket 1150) DDR3 ATX Motherboard - FREE Gigabyte M8000x Gaming Mouse £143.99
1 x XSPC D5 Photon 270 Reservoir/Pump Combo £139.99
1 x Seagate Barracuda 3TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST3000DM001) HDD £99.95
1 x Corsair Vengeance Pro Blue 8GB (2x4GB) DDR3 PC3-14900C9 1866MHz Dual Channel Memory Kit (CMY8GX3M2A1866C9B) £79.99
1 x Corsair Vengeance Pro Silver 8GB (2x4GB) DDR3 PC3-14900C9 1866MHz Dual Channel Memory Kit (CMY8GX3M2A1866C9) £79.99
1 x Corsair Generation 2 Sleeved Cable Kit (AXi / AX / HX / TXM) - Blue £64.99
2 x XSPC EX360 Crossflow Radiator £52.99 (£105.98)
1 x Corsair Generation 2 Sleeved 24 Pin Cable (AX) - Blue £14.99
1 x NZXT CB-LED20-WT 24x White LED Sleeve - 2m £13.99
1 x Mayhems Pastel UV Lime Yellow 250ml £11.99
8 x Akasa AK-FN059 120mm Ultra Quiet Venom Viper Cool Fan - 3/4 Pin £11.99 (£95.92)
1 x XSPC HighFlex Hose 1/2" ID, 3/4" OD, 19/12.7mm, 2m, White £6.98
1 x EK Water Blocks HD Tube 12/16mm 4-Slot (2 pcs) £4.49
12 x XSPC G1/4" to 1/2" ID, 3/4" OD Compression Fitting (Black Chrome) £3.49 (£41.88)
Total : £2,765.16 (includes shipping : £16.85).
