- 9 Dec 2015
Hi,
How do 3 pin fans work when on a hub with 4 pin fans, do they just end up running at 12v all the time while the 4 pin fans operate as normal ramping up depending on temp.
Looking at getting meshify 2 noticed it comes with 3 pin fans and a hub that has 3pin and 4 pin dedicated slots, so assuming you set it up like that and into one fan header how does that work?
Cheers
Cheers
