3rd party monitor stand for hazro
4 Aug 2005
Hello,
Does anyone know of any 3rd party monitor stands suitable for the hazro HZ27WD (and reasonably priced) ? I need to lower it by a few inches.
Thanks
Yes, the only 3rd party desktop mount I could find which could support a 27", using google and searching the bay, had a minimum hight of 10cm which is about the same as the standard Hazro. So maybe the only way to get it less than 10cm is to put your desk against a wall and wall-mount the screen. Of course you may will, I hope, find something better. In fact it was one of the many reasons I got a dell rather than hazro when I chose my 30"
That seems like rather silly reason since the 30" Hazro comes with a height adjustable stand unlike the 27".
Anyhow, you may need to look at desk mounts rather than normal stands, there is wider selection of them. Months ago the Hazro representer posted they were working on a after-market stand for the 27" models.. haven't seen it though.
