Appreciate some expert guidance from the the forum.
It might be there is a far simpler solution to add to my existing set-up that will improve WiFi and also help with the laptop problem - i.e. just ad several Powerline Adapters like the Develo Magic 2 WiFi.
Current Sky Products
1. Poor and intermittant WiFi - frequent drop outs 2.4Ghz and 5 Ghz or very low download/upload
2. Laptop used in a room for work meetings over WiFi - connection very poor
Potential Solutions
1. Improve WiFI
- Sky Broadband Superfast
- 1 x Sky Q Box - hard wired connection (kitchen)
- 3 x Sky Minis - wifi connection (bedroom, lounge, dinining room - no simple known option to hard wire)
- 3 x Sky Boosters
- 1 x Sky Hub (under stairs cupboard - cannot be moved as all wiring returns here as a hub)
- Wired minimum download Speed 79 Mb/s, average upload speed 20 Mb/s
- WiFi speed when good (50% time): download 22 - 55 Mb/s, upload 5-18 Mb/s
- WiFi speed when poor (50% time): download 0.3 - 4 Mb/S, upload 1.7 - 5.9 Mb/s
Potential Solutions
1. Improve WiFI
- Replace Sky Hub with 3rd party router (under stairs) and a 3rd party modem (under stairs) and install Ubiquiti AP AC Pro x 3 wired throughout the house to serve as WiFi transmitter
- Potential to hard wire 3 Sky Minis
- Issue: - v. high cost £1k+, significant cosmetic repair in/outside house diverting existing wiring
- Powerline Adapters: Devolo Magic 2 WiFi. Plug Sky Minis into ethernet on Powerline Adapters
- Would this work and are these the best Powerline Adapters to get?
- Where would main powerline adapter be best to start and why - plug into 3rd party router under stairs or hard wired Sky Q box in kitchen?
- Would WiFi on Poerline Adapters need to be turned off or ok to use as further booster for house
- Potential to hard wire in the room laptop used
- Powerline Adapters: Devolo Magic 2 WiFi. Plug laptop into ethernet on Powerline Adapte
- I assume main powerline adapter plugs into 3rd party router under stairs?
- Would WiFi on Powerline Adapter need to be turned off or ok to use as further booster for house
