- 18 Oct 2002
- At home
Hi,
I'm currently in the process of implementing wireless to a select few users here ( directors / partners etc ) however using the standard windows software it seems to just scan and connect you to any access point. And then auto connect whenever in range.
Is there anyway to block this as there are a few access points very close to our office and I don't want it to auto connect. Possible to make it a manual process for every connection automitically.
I know you can set up individual connections to be manual but would require the user to do this.
Thanks.
Thanks.
