3x Display Workstation
1 Mar 2015
Hi, I need to build a replacement for my current PC, but gradually as I can't afford to buy everything in one go. The machine will be used for work, primarily a very busy Firefox, and image and video editing. Not gaming, but I like fast, and I want the new machine to run comfortably for 5+ years.
My displays are a Dell 3008WFP flanked by 2007FPs, driven by a 2GB Gigabyte GTX 650. I'm not mad about the card, it makes the VGA-connected side monitor the primary which is annoying if anything goes wrong, but I'm not averse to keeping it. I have 2 optical drives that can be kept, and a relatively recent SanDisk Extreme II SSD that can probably stay.
I don't think I really need anything else in the case to be honest, maybe a mechanical drive or a different motherboard if I'm changing the video card, but you guys will know better than me about that. I would like 4 front-mounted USB ports on the case though, and ideally a front cover. I like the unadorned looks of the Antec P280 and P100.
I don't mind spending on the CPU and RAM and had picked the i7-4790K as a base, but then I decided to come here and ask the experts before going any further. I'm comfortable building a system but I've never overclocked and deciding on motherboards in particular is outside my comfort zone.
I'd appreciate your help picking a motherboard and maybe a replacement video card(s), I can probably handle the rest of the components myself.
EDIT: I should add, I'd prefer quiet over not.
As I said in my post, I'm comfortable building a system, the only thing I've ever been nervous about is installing the CPU, but I've done it one so it should be fine.
Budget is about €1k total, but it's a gradual build so I'm not tied to it. I'd prefer to spend on the right CPU and motherboard now for the sake of longevity.
YOUR BASKET
1 x Gigabyte X99M Gaming 5 - Intel Core i7 5820K Six Core CPU & Motherboard Bundle ***£20 Saving*** £459.94
1 x Adata XPG Z1 16GB (4x4GB) DDR4 PC4-19200C16 2400MHz Quad Channel Kit (AX4U2400W4G16-QRZ) £199.99
1 x MSI Radeon R7 260X OC 2048MB GDDR5 PCI-Express Graphics Card £89.99
1 x Antec P280 Super Midi Tower Case - Gun Metal Black £84.95
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £66.98
1 x Antec TruePower Classic 650w '80 Plus Gold' Power Supply £60.95
1 x Be Quiet! Shadow Rock Slim £33.95
Total : £1,014.44 (includes shipping : £14.75).
X99+16GB RAM.
The GFX card has display port (for your 30") and 2x DVI for your two 20" screens so that eliminates you using old VGA.
The PSU is overkill but I'm hoping because it has to work so easily powering this the fan will naturally spin slower.
Thanks stulid, I'll go through those properly later. One thing I did notice in the 2nd build is the use of HDMI, I think the resolution is limited to 1080 over HDMI on the 3008WFP, and the 2007FPs don't have HDMI ports. The card in the first post should be fine though.
Yes lee32uk, but as I mentioned to stulid, I'm not really locking myself down to that; I'll be buying the parts individually over time, so if a higher price gets me a better machine it'll just take me longer to build. Within reason, obviously. :)
You can get HDMI-DVI cables - http://www.overclockers.co.uk/showproduct.php?prodid=CB-018-OK&groupid=1929&catid=1753
I assume they work perfectly and without any weirdness.
X99 doesn't have a built-in GFX core but the Z97+4790K does, the board has three display outputs you can use and get a GFX card later,
http://www.gigabyte.com/products/product-page.aspx?pid=4979#sp
Integrated Graphics Processor - Intel® HD Graphics support:
1 x D-Sub port, supporting a maximum resolution of 1920x1200@60Hz
1 x DVI-D port, supporting a maximum resolution of 1920x1200@60Hz
* The DVI-D port does not support D-Sub connection by adapter.
1 x HDMI port, supporting a maximum resolution of 4096x2160@24Hz or 2560x1600@60Hz
* Support for HDMI 1.4a version.
Support for up to 3 displays at the same time
Maximum shared memory of 512MB
Thanks. Is there a reason to go for the HDMI card over DisplayPort? There doesn't seem much point in messing around with convertor cables for the sake of a tenner.
Is the X99M board overclockable? I haven't done any overclocking, but I'm not averse to it. (That being said, is the 5820K overclockable, or has Intel already done that? Sorry, showing my ignorance here.)
I looked at the rest of the specs and I don't think I have any other questions at the moment. I'll probably come back about fans and the PSU later, but there's 3 months in acquiring the case, mobo and CPU so plenty of time. :)
Thanks again for your help!
Displayport is superior to HDMI and has more bandwidth so supports higher resolutions/Hz.
(although I think its HDMI 2.0/1.4b or something that improves on this).
Yes the X99+CPU listed above are overclockable.
Is there any way of figuring out an approximate wattage for this machine when it's built? I've gone looking on the tubes but many of the components don't provide a wattage, and most of the testers use total system usage as a benchmark for individual components. I'm not looking for anything precise, in the hundreds would be fine, I'm just looking to source an appropriate UPS.
Pardon the bump, I said I'd post in the same thread for reference. I have everything on this list now bar the video card and an SSD.
I'm slow to order the video card I had chosen ( MSI Radeon R7 260X OC) because it seems to be EOL, what would be a good replacement for that? Again, I'm not a gamer so I'm more concerned with ports, nice output for text and video, and reliability.
Also, the disks that were recommended were SATA and I'd prefer SSD, ideally using the M.2 port as I believe that'll be the fastest route. Finding one is proving tricky though, I've had to throw myself into learning the difference between SATA and PCI-E M.2 disks, etc! Any recommendations? I believe the X99M GAMING 5 uses 2x PCI-E paths, is that correct?
sata is connection type
m.2 drive basically a stripped down ssd on a card that connects to the m2 socket on the mb , faster yes but some have reported configuration issues with booting/setup
Really only applicable if you have multiple graphics cards
Can I ask where you read that? I'd like to read about it.
I was talking about the M.2 card, I'm not sure if they come with 4x capability by default, but if they don't then I assume I'd save money by buying a 2x card. That's assuming I read correctly that the mobo only supports 2x.
